Data decimation based on statistics
Hey,
Has anyone toyed with data decimation and statistics in LV? I.e I'm thinking something like an adaptable moving average filter for decimation, that stops decimating once something was outside of 4.5 sigma or so of the other measurements, and once it returns to that bound starts decimating again. Basically something that decimates a straight line but not anything that is a glitch (voltage spike, etc). This would be for scope waveforms - similar to LeCroys top function vs max.
Thanks!
David
(3,733 Views)
Hi David,
I'm thinking something like an…
As LabVIEW is a programming language you can turn your "thinking" into "programming"! 😄
What exactly do you have problems with?
(3,695 Views)
I am not seeing anything that couldn't be done fairly easily.  What do you want done in your waveform when outside the 4.5 sigma?  Delete the time sample?  Make it NaN?  Use previous average?
(3,690 Views)
Time to see if I can get it working 🙂
Just wanted to make sure it wasn't done before - I am a fan of code reuse.
(3,653 Views)
