Data extraction from string
I'm trying to search a particular value in a string file. The string contains many parameters followed by their values and units. I want to identify and extract, as a number, the value of a particular parameter. The program will basically ask the user to type in (or select from a list of given) parameters in a dialogue box. Then it should display the value of the parameter.
The string I'm trying to work with, is of the form:-
SensorOneInMM,34585
BatteryVoltageInmV,19761
BattTemp1InC,20
CliffDistanceLeftInMM,60
CliffDistanceRightInMM,60
RightSensor,0
LeftSensor,0
CurrentInmAforMotor, 789
TestingCurrentInmA, 123
Temp1InC,28
Temp2InC,28
BaseCurrentInmA,1342
ChargeInmV,218
CurrentInmA,9999
NotConnected3,0
Now, for example the value I want to read is the one in Blue color. But the expression, "CurrentInmA" appears several times, in the string. How can I identify the value of the parameter in Blue color??
Thanks for helping out an amateur!!!
Cheers.
(3,893 Views)
Hi RAJ,
There are plenty of ways to do what you are after, here is just one:
Im sure there are better ways though,
Rgs,
Lucither.
"Everything should be made as simple as possible but no simpler"
(3,885 Views)
This will also do the job:
MC
(3,872 Views)
Rajat
I think  you want to extract the value from specific string..
you can get number of post releted to your question...few are follow
Post 1
Post2
also see attached vi which specific to your problem..
(3,860 Views)
I like to use Match Regular Expression.
^ locks the match to the begining of a line.
(\d+) will return just the digits out the submatch. Expand the Match Regular Exptession down to add submatch output.
Omar
(3,812 Views)
Kudo to Omar for the use of submatch. An alternate to Omar regular expression can be \bCurrentInma,(\d+) where \b is a word boundary (match between a word character, letter-digit-underscore and a non-word character), in that case you don't have to set the multiline input to TRUE.
(3,790 Views)
