Data format problem with Write to Spreedsheet File
I have a problem with the data format with Write to spredsheet file.
I have an N*3 array, where the 3 elements in each row should has different length. When I used Write to spreedsheet file,
it can only save the three data in one format. How can I save them in the format of "%0.8f %0.3f %0.2f"?
Thanks for your help.
(3,684 Views)
Hi powerplay,
WriteToSpreadsheet is made for generic purposes. If you need something special, you have to program something special...
Make a for loop to auto-index through your array, use a FormatIntoString inside the loop to format the values. Either append the strings in the loop or use autoindexing andArrayToSpreadsheetstring afterwards...
(3,680 Views)
I believe the same issue was presented here
Tim Elsey
Certified LabVIEW Architect
(3,672 Views)
Hi powerplay,
another solution may be to convert column-wise using "number to fractional string", then interleaving resulting arrays and again using "array to spreadsheet string" (with "space" as separator).
Many ways lead to Rome Smiley Wink
(3,652 Views)
