Data frequency acquisition
Hey mates, thanks for attention.
I am using NI 9205 to acquire voltage and NI 9213 to acquire temperature.
They have very different acquisition frequencyes: 250 kS/s and 75 S/s.
I have no problem with this, my temperature measurement will be less than voltages. The question is: How to do to make then work toguether ?
In labview: I am using 1 Daq app I set continous sampling  5k Hz as sample rate and 1k as samples to read for NI 9205 voltages and other Daq app with 5 Hz 1 sample for NI9213 tempeerature. I get aways problems whit buffer size.
Should I use 2 Daqs in my labview VI ? How to make then with just one Daq app ?
Thanks again,
Arthur.
(4,035 Views)
Accepted by topic author Arthuruuuuuu
You can either have two separate while loops, one for each DAQ read, or change the "number of samples per channel" input to -1 which will return all available samples. If you can post your code that may be helpful to look at as well.
(4,010 Views)
What chassis are you using?  Does it support multiple AI sample rates?  If so, you just need two DAQmx tasks, one for each sample rate.  I would go so far as to have a different loop for each task and use Queues or User Events to pass the data to loops that need it.
(4,009 Views)
