Data logger and online processing application
Dear All
My application should include both data logging and online processing threads which are synchronized. I already implemented that by means of something we call "Ring buffer" which is an array containing the data and when the data stream reach its end it start over again from first index. It works almost well but sometimes it seems that my "timed loop" which is my processing thread is a little bit ahead of my data logger thread and it makes some distortion on data stream in processing thread but of course not in data logger.
Since this type of application is very classic, we should have a kind of general prototype (example) for its implementation which provides fully synchronization between processing and logger threads so I was wondering if somebody knows where I should look into?
Best regards
Afshin
(2,743 Views)
Hello Afshin,
Have a look at Software Circular Buffer in LabVIEW [link removed; page no longer available] and Software Circular Buffer Reference Library for Multi-Channel Data Acquisition.
The latter comes with an example.
Eirikur Runarsson
(2,709 Views)
