Data logging every 10 seconds
I started learning labview in the last few weeks and I would be so thankful if you give me a hand. I want to log data every 10 seconnds. I already checked the solutions with the elapsed-time-function in the forum but it seems that it only works with the Mean VI. Can you please take some of your time and look into this VI ?
best regards
Ezzow
Message 1 of 19
(5,196 Views)
Message 2 of 19
(5,177 Views)
Thanks   for your time.
Can you please explain how can I integrate your solution in my Code? I'm new to the whole technology. Thank you so much.
Message 3 of 19
(5,173 Views)
There are a lot of open questions.
  • Do you want to only save the current data every 10 seconds?
  • Do you want to accumulate data for 10 seconds then save all to disk?
  • We cannot tell from the picture anything about the express VI configurations and dynamic data content. Showing such a picture to explain a problem is useless.
  • How many points do you get per iteration?
  • What is the current loop rate?
  • Most more advanced users get rid of express VIs and dynamic data pretty quickly. It's just not flexible enough.
Message 4 of 19
(5,148 Views)
Put the Write To Measurement File express VI in the true case as before.
Remove the Elapsed time express VI (the compare of timestamps replaces that).
Message 5 of 19
(5,140 Views)
Thank you @altenbach for your time.
I want to save one point every 10 seconds. I mean from all the data between t=0s and t=10s in a loop. Which means I should get one point every 10 seconds.
When I use the same code with the Mean VI instead of the derivative VI (to calculate the average) it works perfectly.
I also attached the complete VI in my first post.
I only simulated a simple Sinus signal with a frequency of 10.1 Hz. I'm not sure how much points it generates per iteration.
I'm afraid I can't answer this question. It's a normal while loop.
I'll try it later with the real data of a thermocouple that I connected to a CompactRio.
Message 6 of 19
(5,108 Views)
Thank you @altenbach for your time!
I'll try to answer your questions.
I want to save one point every 10 seconds without causing any delay to the original signal. In addition I want to be able to change this time interval anytime. Maybe to save one point every 2 seconds .. The thing is that the same code works perfectly when I put a Mean VI (to calculate the average) instead of a derivative VI like the one on the picture.
I also attached the original VI in my first post. Maybe it does answer this question ? 🙂
I'm afraid I can't answer these two questions. I only generated a simple sinus signal using the signal simulator (Express - Input - signal simulator).
Well, I'm just testing with the signal simulator. My real data comes from different sensors which are connected to a CompactRio system. I don't no if there is a big difference to log data between the signal simulator and the real data.
Message 7 of 19
(5,114 Views)
I cannot open Vis in LabVIEW 2021. If you would "save for previous" I could look at your express configurations. "Simulate signal" has plenty of configuration options (samples/second, # of samples, run as fast as possible vs. simulate timing, etc.) Since you configured it, you must know it! For example, you cannot take the derivative of a single point. Right (unless you use a ptbypt tool)
Message 8 of 19
(5,104 Views)
It's working now with the same code I had at first 🤔
However, I'm facing another problem now. The function ''write to measurement file'' is not working as I acquired the real Data from an my RTD sensor using a CompactRio-9047. In other words I don't get my Data saved in any folder in the computer. I also read that CompactRio system must have its own storage space. Could you give me a hand ?
I also don't understand why my signal isn't appropriately derivated. Normally I should get for a linear function after the derivation a constant one. However, it's not the case. Does LabView derivate in other ways or did I mess something?
I also attached the code I used.
Thank you for your time.
Message 9 of 19
(5,014 Views)
The input seems to be a sine, the derivative is a cosine. Looks right to me.
Message 10 of 19
(5,000 Views)
