Data overflow or sampling rate problem?
Refer to the section on passing boolean parameters from the KnowledgeBase called "Creating and Calling LabVIEW DLLs with Various Data Types from Microsoft Visual C++".
In case you find the boolean data type too complicated, you can just use an integer instead and have LabVIEW convert using the "Boolean To (0,1)" function.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 11 of 11
(362 Views)
