Data overflows after LabVIEW reads it from WinSpec
Hi there,
We have a software (WinSpec) that controls a spectrometer.
This software works perfectly fine; reads the data correctly and everything.
However, when we use labVIEW to read the data from the software, the results come out as overflow (very large numbers become negative).
The weird thing is that we do not have this problem on another computer that is using the exact same LabVIEW program and the same WinSpec version!
Thanks!
(2,932 Views)
Please be a little bit more specific about what you'd like to do. Which LabVIEW version are you using?
How do you read  the data from WinSpec into LabVIEW?
regards
(2,907 Views)
