Data point sets for the interpolate 1D array vi
The HELP info for Interpolate 1D Array states that you can input an array of numbers OR POINTS. What format would you input points, or "data point sets" as the help states?
(3,542 Views)
Hi etd,
see the attached example. One works with an array and the other one with array of cluster, like described in the help. Hope it helps.
Mike
(3,532 Views)
Thanks Mike,
That helped!
(3,509 Views)
