Data rate between LabView and DSP using a RTDX channel?
I'nm using LabView 7.0, the DSP test integration toolkit, and a DSP TMS320C6711 DSK.
I would like to know more specifications about the data rate that is possible between the DSP and Labview using a RTDX channel.
Thanks.
(2,878 Views)
National Instruments doesn't have any benchmarks for RTDX throughput. This may be a better question to ask of TI, however they may not have much for benchmarks either as it would depend on the code running on the DSP. I did find a document that may be helpful on TI's site: How to Optimize Your Target Application for RTDX Throughput. You can also search their site for more info.
JR A.
Application Engineer
(2,878 Views)
