Data recording excel or text file
Is there a way to select some variables from a VI and save the values from those variables alone in an excel file?
When saving data to excel or for that matter a text file, is there a way to get the data label as a header in the excel/text file?
I have an application where the variables I record from the same program are different each time. If I use the write to file feature, I have to manually type my header.
Seems to me that there has to be a easier way to do this.
Message 1 of 12
(4,369 Views)
What data label are you talking about? Is it something you read from an instrument?
Message 2 of 12
(4,360 Views)
Dennis,
It can be data aquired from an instrument or data displayed as a result of a calculation in LV.
I am posting the VI tht I am using right now.
There is a place where I have to manually type the header information. Suppose if the data I am recording was from an instrument, this will be a tag id.
Message 3 of 12
(4,336 Views)
Tags can be easily written to a file. It's just a string write. You could write columns with a single Write to Spreadsheet File and the Data with another.
Message 4 of 12
(4,322 Views)
But I will still have to "type" manually the string right?
Message 5 of 12
(4,317 Views)
If you read the string from something, like you said, you would not have type anything. I asked where the label came from and you said it was coming from an instrument.
Message 6 of 12
(4,310 Views)
Yes. Although not all tags come from an instrument.
There are calculated data that I would like to store also in the excel/text file.
How can I write the label of the data onto the excel/text file ?
Message 7 of 12
(4,305 Views)
There is no name associated with a wire. You can label a wire. Is that what you want to extract?
Message 8 of 12
(4,299 Views)
I want to extract the label of an indicator/controller
Message 9 of 12
(4,291 Views)
You simply use a property node to get the text of the label or caption.
Message 10 of 12
(4,278 Views)
