Data saving from PIC code
hello,
I was trying to save my experimental data from PID code. I used the queue options but I can't get any saved file on my computer. I have attached the PID code here.
Would anyone check and help me to solve the problem? TIA
(4,488 Views)
Could you send your file in the 2015 version ?
What is the size and the type of the data ?
Kudos are welcome! Smiley Wink
(4,468 Views)
You are not putting any data into your Queue only a Boolean (Stop)
=== Engineer Ambiguously ===
(4,449 Views)
hi RTSLVU,
Actually, I followed another example. Would you please modify the code?
Thanks in advance
(4,438 Views)
Hi Fred19ni
I have attached the 2015 version of my code here. Actually, I want to save numeric data from the sensor. I have low knowledge about data type and size. Sorry, I can't give the exact answer to your question.
(4,436 Views)
Hi Chowdhury_Milon,
I can't open this file because it's the 2017 version, not 2017.
Anyway, if you want to save numéric data, you can use Excel file.
Kudo are welcomeSmiley Wink
(4,421 Views)
Accepted by topic author Chowdhury_Milon
1. You have a data dependency between your two loops.  Data flow will therefore dictate that you second loop connect run until the first loop is complete.
2. You are just using the queue as a stop condition.  You need to pass the data through the queue.
3. Get rid of those Dynamic Data Types whenever possible.  They make things more difficult to understand.
You might also want to give the Producer/Consumer a good read over.  But here is your VI set up to be a proper Producer/Consumer.  You still may need to tweak things to get the display and file format the way you want it.
(4,418 Views)
