Data socket generate vi can't connect to Data socket Read vi
I'm trying to learn about remote data management basics but I can't get my Generate and Read VIs to work. The Data socket Read vi can't connect to the data socket generate vi. I've attached the codes for two VIsl. I get an error message when I click the stop button on either VI. I'll appreciate any help here. Here is the error message below:
  Error 63 occurred at DataSocket Open in DS Read Data.vi
Possible reason(s):
LabVIEW:  Serial port receive buffer overflow.
LabVIEW:  The network connection was refused by the server. For TCP/IP, make sure the server is running and listening on the port you are trying to use. Firewalls can also cause a server to refuse a connection. For VI Server, make sure you have enabled VI Server from Tools>>Options>>VI Server:Configuration.
(4,371 Views)
Don't Close & Open so much. See attached VI's, these run fine for me.
Minor things: Short timeout in Read lets it close faster. Also, your slide was set to 100. I've set the URL's to typical defaults.
Richard
(4,362 Views)
Hi Broken Arrow
You have the 8.6 latest version of labview and I have 8.2 so I can't open your VIs. Can you try a lower compartible version?
(4,356 Views)
try these
Richard
(4,354 Views)
Hi Broken Arrow,
I'm trying to create a data socket connection for a numeric indicator on the front panel of the DS Read VI but when I right click the indicator and go to Data Operations, there is no "Data Socket connection" option. Is there another way of creating a data socket?.  I have laview 8.2 Student edition and I'm wondering if this is the reason the DS option was not available.  I'll appreciate any help.   Thanks
(4,331 Views)
Does anyone have anything to say about the last question I posted?.  I'm still awaiting a reply.
(4,316 Views)
That method of connecting to a datasocket is from a much older version of LabVIEW.  In 8.2 (or higher), right click the indicator and go to properties.  There you will see a data binding tab that has the configuration settings you are looking for.
Chris Bakker
SET Americas
CEO
(4,304 Views)
