Data transfer LabView/Simulink through TCP
Dear All,
My problem is to send data stream from LabView to Simulink (and then results obtained in Simulink transfer back to LabView) using TCP protocol.
To send data I use (a little changed) example from LabView folder (‘TCP Data Server - Touch Panel.vi’). It is possible to connect server with client. However I have a problem. It is not possible to read data sent through TCP, I have following error:
“Error evaluating registered method 'Outputs' of M-S-Function 'stcpiprb' in 'untitled/TCP//IP Receive'. The specified amount of data was not returned within the Timeout period.
Please ensure that data is being sent to the specified port or specify a greater timeout value.”
If I understand well data type send by LabView is different that data expected by Simulink problem. How can I force LabView to cooperate with Simulink?
Is there anyone who solve this problem?
Miro
(3,665 Views)
Dear All,
This Topic is discussed under this Forum page:
Data transfer LabView/Simulink through UDP -
http://forums.ni.com/t5/LabVIEW/Data-transfer-LabView-Simulink-through-UDP/m-p/1517084
Regards:
Tamas
(3,628 Views)
