DataSocket Read problem
Hi all,
When I use the new condensed "DataSocket Read" vi in Labview 6i (which is
unfortunately not editable and is supposed to replace old vi's like "open
connection", "update", "close" and so on) a single time to read automat
words through an OPC server, the vi returns "zeros" all the way. The only
solution I found to read the right datas is to place the "DataSocket Read"
in a "While Loop" which loops until datas are different from zeros, which
is very inconvenient and time consuming. I tried diffferent settings with
"DataSocket Read" (wait for update, timeout) but the problem remains.
Have you also faced the same problem ? Is there a solution ? Thanks for your
assistance.
Gaël RENEVIER
Responsable Maintenance & Développement
Tél : 04 74 82 20 08
Fax : 04 74 82 24 92
e-mail : grenevier@tecumseh-europe.com
(3,407 Views)
Select open from the file menu and browse to the following location : labview
6\vi.lib\platform\dataskt.llb. I think this library has the vi's you are
looking for. I hope this helps.
Jared
grenevier@tecumseh-europe.com wrote:
>Hi all,>>When I use the new condensed "DataSocket Read" vi in Labview 6i
(which is>unfortunately not editable and is supposed to replace old vi's
like "open>connection", "update", "close" and so on) a single time to read
automat>words through an OPC server, the vi returns "zeros" all the way.
The only>solution I found to read the right datas is to place the "DataSocket
Read">in a "While Loop" which loops until datas are different from zeros,
which>is very inconvenient and time consuming. I tried diffferent settings
with>"DataSock
et Read" (wait for update, timeout) but the problem remains.>>Have
you also faced the same problem ? Is there a solution ? Thanks for your>assistance.>>>Gaël
RENEVIER>Responsable Maintenance & Développement>Tél : 04 74 82 20 08>Fax
: 04 74 82 24 92>e-mail : grenevier@tecumseh-europe.com>>
(3,407 Views)
This is a problem with the 6i data socket routines ... use the old routines
from the data socket examples (with the open,update, close drivers), and it
works fine.
Dave Gianetto
http://www.gianetto.org
> From: grenevier@tecumseh-europe.com
> Organization: UUNET
> Newsgroups: comp.lang.labview
> Date: Tue, 21 Nov 2000 16:05:38 +0100
> Subject: DataSocket Read problem
> Hi all,
> in a "W
> assistance.
> Gaël RENEVIER
(3,407 Views)
