DataSocket Server Manager Crash
I have the following problem.
I call DataSocket Server Manger. Once the application is loaded, its window does not show the text. There are no bugs. The DataSocket Server Manager version is 4.5 (21). I use Windows 10 (64 bit). The problem is displayed on two different PCs with LabVIEW 2010 and LabVIEW 2015. Anyone have a clue of the problem?
Thank you.
Message 1 of 11
(5,212 Views)
I have the same problem with Labview 2021, windows 10, datasocket version 4.5
Datasocket server works, but datasocket server manager does not show any variables or text in the left pane. Only + and - signs that does nothing when I click them.
Have you solved the issue?
Message 2 of 11
(5,138 Views)
I am having the same issue.  Anybody have any advice on how to fix this?
Message 3 of 11
(5,072 Views)
I misread the original post.
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(5,067 Views)
Hello everybody,
I have exactly the same problem with Windows 10, LabVIEW 2011 and the same version of the Datasocket Server Manager.
Thanks in advance for any hints!
Message 5 of 11
(4,992 Views)
I have the same issue and I'm yet to resolve it, but I'm wondering if there is some missing driver or package that the datasocket manager is dependent on to get the text.
I've installed LV2021 x86 on two Win 10 PCs.  The Dell laptop is fine, but the Latte Panda install is the one with the issue.
I vaguely recall deleting some of the options for the Panda install as I was short of time.
I'll probably try a full uninstall and reinstall of LV2021 with all the default options.
Message 6 of 11
(4,969 Views)
I opened a technical support request with NI and they acknowledged it's a bug they are investigating.  As a work around, it was suggested to create the configuration needed in a PC that is not presenting the issue and transfer the cwdssini.dss file to the PC having the issue.  My customer didn't like this solution and we never attempted it.
As an alternative, we used shared variables to achieve the functionality that we needed.
Message 7 of 11
(4,944 Views)
I tried transferring the .dss file from a working system without success.
I realised that I have a third party software package (Tektronix signal vu - for their RS306B spectrum analyser) which I believe uses either Labview based code or something similar that talks to the instrument.  I've uninstalled that, and now my program with a serial port doesn't work.
So I'm currently running a repair on the Labview install to see if I can get it back.
Good to see NI acknowledge it.
Message 8 of 11
(4,928 Views)
One thing I noticed was that after starting datasocket server manager after a reboot it was working, but when I started Labview it wasn't.
Message 9 of 11
(4,920 Views)
I have the same problem. LabView 2017, windows 10
Message 10 of 11
(4,719 Views)
