DataSocket and For Loop
Hi all,
I try to use DataSocket Read (from LabView 6i) within For loop changing adress with every iteration. I need to read data from 50 computers so I thougt this was the best way. But it doesn't work correctly (or I'm doing something wrong) - time out doesn't work at all. Everythink is ok when I read data for each computer separately.
So is it possible to use DataSocket Read and For Loop (different data sources) ?
Kacper
p.s. sorry for my english (pseudo english ?)
but it's not my native language
(2,711 Views)
If everything is working fine for each computer, it seems that the problem is time related. Try to find out the necessary time for one read (use 2 time stamps - before and after) and use the resulting delay inside the loop (even a little bit more).
(2,711 Views)
