Databasa Connectivity Toolset Reading Performance
Hi.
I'm using DCT to read two tables from access db, each containing about
3000 records with about 20 fields.
The reading time, using standard systems, like in examples, like
Connect to DB, Get Table, close connection is more than 5 minutes wit
100% processor time.
After this Huge time amount, it is necessary reprocess the array to
convert it in appropriate LabView data type.
Anyone has some Ideas to survive?
Note: writing is Quicker: more than 100 records per second.
Thanks in advance, OldSmobile
(3,477 Views)
The following link discusses the read performance of the Database Connectivity in detail and ways to optimize.
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/862567530005f0a186256a33006b917a?OpenDocument
(3,477 Views)
Thank you!
Unfortunately at present that link seems not been working... I'll try
later, or if you can give me some indication on how to re-find it i'll
not stress you for this 🙂
OldSmobile
(3,477 Views)
I'm sorry I gave you an internal web link.
Search the Knowledgebase on www.ni.com for KB 28IDHE52.
(3,477 Views)
You are really kind!
I found the solution to slow data reading.
Now I have just to convert from string to the appropriate data type...
but I have a VI that will do it for me! :-))
Thank you again.
OldsSmobile.
(3,477 Views)
