10-24-2007 03:17 PM
As far as the toolkit not being able to be used in 8.5 without loading an older version of LV is not true. I loaded the developers kit on a new PC just the other day and the toolkit works just fine. In fact I am using it right now for some database things. The only problem that I have had with it, is that the variant to data vi would not go on the block diagram from the functions pallette. I searched the KB and found a workaround that worked and now it runs just fine. I have never seen that error that you posted.
I am sure that NI has tested the toolkit with all of the versions of LV.
10-25-2007 02:35 PM - edited 10-25-2007 02:35 PM
Message Edited by Travis M. on 10-25-2007 02:37 PM
11-13-2007 09:29 AM - edited 11-13-2007 09:31 AM
I can only say when I install labview 8.5 and the toolkits all install to the wrong labview version directories until I uninstall them all from my system first and then reinstall them to 8.5 until I finally get everything in he right place...
None of my applications will open because they are calling 5.1 database connectivity vi's and 8.5 can't open them until I mass compile them. I'm sure anyone would agree that If they are shipping with labview 8.5 they should be shipped in an 8.5-compatible state.
I took your suggestion and started new threads about additional problems. I'm sorry but I keep finding really serious problems every time I try a feature I haven't tried since upgrading. When I stop finding new problems I'll be happy to stop posting.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=283992
http://forums.ni.com/ni/board/message?board.id=170&message.id=283727#M283727
11-13-2007 12:56 PM
12-12-2007 08:33 AM
12-12-2007 09:08 AM
billings11 wrote:
2. The database connectivity toolkit ships with many vi's in labview 5.1. Labview 8.5 will not compile 5.1 vi's. So you cannot use the database connectivity toolkit without installing an earlier version of labview on the same machine and using it to mass compile to something between 5.1 and 8.5. Labview 8.5 can't do it by itself.The bugs are an annoyance, my real issue is that the toolkit obviously was never loaded to a clean 8.5 install and used by anyone at NI or they would have seen the compiling problem. So the point is toolkit functionality is not checked from release to realease by NI.
12-12-2007 09:11 AM
Do you have a previous version of labview on the machine? The Report generation toolkit, like many other toolkits, installs to the older version of labview if you have one. If you install 8.5 over 8.2, the toolkit will install to the 8.2 directory. The same is true of the internet toolkit, the database toolkit, etc. Even DaqMx will install to the wrong folder if you uninstall it and then reinstall (the second time through it goes to the wrong folder).
You have to go into add/remove programs and uninstall the toolkit first. Then it should install to the new version. Then if you want to have it still included in the old version you have to install it again I think. The toolkit installers are all buggy and have been for years. And most of the toolkits have had new bugs pop up do to labview version changes that are not addressed because they are a low priority.
12-12-2007 09:17 AM
Hi Billings,
You sound perfect.
i forgot to put it that i do have LabVIEW 8.2 installed. and also the toolkit.
Let me try uninstalling all tool kit of 8.2 and try install for 8.5
Thanks for your advice. will let you know as soon as i complete it...
12-12-2007 09:31 AM
12-12-2007 10:30 AM
Well it's not that they are really buggy but VERY limited. They have this annoying limitation to only install once on each machine, eventhough I have just about every LabVIEW version on it since LabVIEW 5.0. So what I usually do is install it once, which usually goes into the highest currently installed LabVIEW version and then copy it over to all other LabVIEW versions. It's a pain and I hope they will finally remedy that with the next major LabVIEW upgrade, eventhough that might probably mean that most of those toolkits will be also tied to the license manager control like all the rest of LabVIEW.
That DAQmx removes support from earlier LabVIEW installations was a real disappointment for me. It should not remove it but upgrade it!!!!
Rolf Kalbermatter
