Database Connectivity Toolset
I am working through the manual to understand the functions. On page 3-12 the Block Diagram shows a RUN TEST (.vi ??) without explanation and a "Test Results Array". Is there suppose to be supplied examples buried in some .dll?
Though I was able to successfully TEST the Citadel connection there does not appear to be much information about accessing Citadel itself. Is there a better source of information?
RL
(3,033 Views)
RL -- I will make a note of this to look into the next time we revise this manual.
If you have feedback on any National Instruments documentation, you can send it to techpubs@ni.com.
Thank you,
Kelly Holmes
Kelly H
LabVIEW Documentation
(3,033 Views)
Yes, there are several supplied examples with that toolkit. Select Find Examples from the Help menu, double-click the Communicating with External Applications in the task view, and double-click the Databases item.
The manual provides additional examples that are not included in the Examples directory but you can easily create those VIs using the diagrams and panels shown; especially after you've examined the shipping example VIs and understand the basic format of the database connectivity VIs.
(3,033 Views)
