Database Query Error -2147467259 ADO Error: 0x80004005
Hello sir,
            The same problem rised for me but its quite different from your explanation...
            please clarify my doubt and attached the snapshot of error...
            thanking you
Message 21 of 24
(2,000 Views)
Accepted by mikeporter
The error number is a pretty generic Microsoft COM Error number. However the description in the text makes me believe that you got a mixup about 32 bit and 64 bit ADO/ODBC drivers.
If you run on a 64 bit system, you have two different ODBC managers. One in C:\Windows\System32 which is 64 bit and the other in C:\Windows\SysWOW64 which is 32 bit.
Most likely you have installed LabVIEW 32 bit and in order to configure DSNs for a 32 bit application you need to run the ODBC Administrator in SysWOW32 but if you select the ODBC Administration tool from the control panel you always start up the 64 bit version from System32.
Rolf Kalbermatter  My Blog
Message 22 of 24
(1,992 Views)
Rereading my reply I saw a typo:
Most likely you have installed LabVIEW 32 bit and in order to configure DSNs for a 32 bit application you need to run the ODBC Administrator in SysWOW64 but if you select the ODBC Administration tool from the control panel you always start up the 64 bit version from System32.
Message 23 of 24
(1,963 Views)
thank you so much sir...
Message 24 of 24
(1,939 Views)
