Database Toolkit Unescape Characters
Hi guys,
I am working with the Database Toolkit with SQLite and MySQL (i'm migrating right now) and I am having a kind of annoying issue with the Execute Query VI.
In SQLite, if i give it a string to its API to write it to the DB, it will just write that string to the DB. In MySQL, using the Database Toolkit Execute Query VI, if i give it a string, it first looks for all escaped (\) characters and removes the \. When you query that column, its missing all the intended \ characters (since it was written without them) which its being handled by my calling code. I would like this to not happen and for it to just write the raw string to the DB.
Has anybody ever encountered this? Is this a toolkit 'feature' or something on the server side? I'm not doing parameterized queries, only a simple format to string and execute query.
(3,666 Views)
There is a Hidden Gem VI called Escape String.  It basically replaces a backslash with a double backslash.  This should fix your issue.
aputman
(3,658 Views)
Accepted by topic author Lee_Denaro
Writing this all down actually made me think it could be a server side issue and turns out it is. if anybody is interested, heres the link on the MySQL website
Thanks rubber ducks!
(3,655 Views)
