Database connectivity toolkit 1.0.2
I have taken over support of some old Labview 8.6 programs.  These programs make use of the Database Connectivity Toolkit 1.0.2.
Both the Labview and the Connectivity toolkit are licenced and I have the serial numbers.  I need to transfer everything over to another PC.  I have the Labview disks but not the Database Connectivity disk.
Can anyone advise where I may be able to obtain a copy?
(1,619 Views)
Hi Rik,
The DCT most probably comes from NI. Maybe it is even included on your "LabVIEW disks"…
In case you don't find it: call your local NI support and ask for help on installing this very old LabVIEW version on your new computers. (They will tell you this combination is not supported…)
(1,616 Views)
This is the case as far as I remember. I believe it's just an option you select in the tree when you install LV and it's probably even on the standard LV DVD, but it might require a disc change. In any case, the installer will tell you.
___________________
Try to take over the world!
(1,553 Views)
