Database connectivity toolkit
Hi Erik,
I am facing the same problem with Database Toolkit. I have followed your suggestion "Replace "Provider=Microsoft.ACE.OLEDB.12.0" with "Provider=Microsoft.Jet.OLEDB.4.0" in the connection string". Still I am facing the same problem. In my case my database is stored in the network.
I tried to debug the code. The problem is with "DB Tools Close Connection" vi. which causes the LabVIEW to crash.
Do you have any solution for network based data access.
Regards
Message 11 of 12
(1,080 Views)
Hi Ismail,
My backend tables database file was an .MDB file (for Access pre-2007), stored on a network share that was mapped to a drive letter, so it is on our network. Can you go into more detail on what you're working with?
Erik
Message 12 of 12
(1,067 Views)
