Database open error -214746725
I continually get the following error:
NI_Database_API.lvlib:DB Tools Open Connec (String).vi->Get DB Columns.vi->GSEDB.vi<ERR>ADO Error: 0x80004005 Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified in NI_Database_API.lvlib:DB Tools Open Connec (String).vi->Get DB Columns.vi->GSEDB.vi
when my program attempts to open an existing SQL database. Some compuiters do ok with it, others produce this error. I know that at least one computer that has the error has Windows7 Pro (64) and at least one that works has Windows 7 Ultimate (32).
(4,529 Views)
Accepted by topic author scottbreeding
Fixed problem by installing the 32 bit MySQL driver on 64 bit OS machines instead of the 64 bit driver.
(4,522 Views)
