Database variant to data function
I have made this program and I want to convert all the database variant to the Labview data type, but in my program the function database variant to data function only converts the first element of the row
(5,124 Views)
You're converting a 2D array of variants to a 1D array of clusters of strings.
Perhaps you wanted to convert to either a 2D array of strings, or an array of clusters of array of strings?
I'd suggest first converting the strings in the clusters to arrays of strings (i.e. the second option) and if that doesn't provide what you wanted, replacing the array of clusters of strings with a 2D string array (the first option).
Note that both of these options will require that you update the output indicator.
(5,116 Views)
If I do like this I have this problem
(5,101 Views)
I made this, but I can see only the first four columns and I want to see all the columns in the "data 2" and I don´t know how to do it
(5,076 Views)
Here's my first option:
Array of cluster of array of stringsArray of cluster of array of strings
and second option (2d array):
I'm not sure if I reordered them since my earlier post (if so, sorry) but I think the 2D array has a pretty good chance of success...
(5,064 Views)
I make it like this and it works! thank you for your help!
(5,048 Views)
Fantastic! Glad to hear that you've succeeded. If the problem is solved, please mark a solution so others know the thread is 'complete'.
(5,042 Views)
