Database
I have created a database in sql server 2005. How can i access it in labview??
Thank you
sushmith
(3,397 Views)
A quick search on NI.com give you NI's database toolkit and SmartSQLVIEW for MySQL, there is also an open source tool called LabSQL but I'm not too sure it's well up to date...
I have used NI's toolkit once in the past (in 2007 in think it was) for a very basic use, it worked.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,391 Views)
SQL Server 2005 isn't MySQL so the SAPHIR SmartSQLVIEW won't work for him.
LabSQL might work. If not, the other option is using ActiveX automation.
(3,362 Views)
What have you tried so far and how did it go?
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,356 Views)
