Datalog I/O File problems in PDA modul?
I have a VI thas save on then read waveform witth Datalog I/O File functions, on PDA I get error "Write Datalog error", the same VI work fine in LabView.
I think that problem is in attributes component of waveform which is variant data type, becuse when I save cluster that contain variant data type I get error but saving same cluster without variant data type works just fine.
Does somebody has any experience with that?
Andrej Panjan
(3,062 Views)
Hi, Andrej.
Let me make sure I'm understanding you correctly: you're saving data to a Datalog file and then later reading the data from the same file. When you're reading data that contains a variant inside a cluster (on PDA), you get an error. Without a cluster, everything is fine. Is that correct?
If so, I'd like to get some more information about the error:
- What VI generates the error?
- Can you please tell me exactly what the error says?
- What sort of data is stored in the variant when you save the file?
- Can you please send me a screenshot or two of your block diagram where you write and where you read the Datalog file?
- What version of the PDA module are you using?
- What version of LabVIEW?
- What Operating System?
- What PDA platform? PocketPC or Palm?
Thanks! Have a nice afternoon.
Sarah K.
Search PME
(3,050 Views)
