Datalogging and supervisory control 2014 with windows 10
We have a full development license for labview 2014 and DSC RT module license now we are planning to add one more client system to the existing server which is running with the above licenses
The new PC is Dell optiplex7060 with windows 10pro after installing the Labview 2014 with DSC RT module  it is showing only labview to be activated and there is no option to activate the DSC module
How can we use it with the new PC?
I have rarely worked with NI Labview so my question may be  silly
Regards
Sandeep
(2,591 Views)
Please try to reinstall the Datalogging and Supervisory Control Module.
(2,539 Views)
But NI people saying windows 10 will not support Labview2014
Regards
Sandeep
(2,523 Views)
LabVIEW and Microsoft Windows Compatibility
The oldest compatible version is LV 2015 SP1
My suggestion is to disable the scroll-wheel or use a mouse without one if you run this version on Windows 10. This will avoid a UI bug that has been fixed in newer versions.
Patrick Allen: FunctionalityUnlimited.ca
(2,501 Views)
