Datasocket Server On RT Target
I'm wondering if a datasocket Server can be used on a RT Target. I can get datasockets working correctly on windows, but I always get errors on the RT.
I have come to the conclusion that you can only use datasocket read/write on a RT Target, but not the actual server.
Is this correct?
(2,820 Views)
Accepted by topic author Lbee11
Hey,
You are correct in saying that you cannot run the datasocket server on the RT system: Which Products Support DataSocket?
To use datasocket in RT, run the server on a Windows host and use the correct URL in the datasocket functions running on RT.
(2,760 Views)
