Datasocket cannot connect to server
This document states that failure to connect to the Datasocket server results in a gray led for controls using data binding.
https://www.ni.com/docs/en-US/bundle/labview/page/reading-front-panel-data-using-the-dstp-opc-ftp-ht...
I have an application that hosts the Datasocket server locally and writes data to this server using data binding. Occationally the LEDs of this program turns gray. What could be causing this since the application is on the same computer as the server?
Craig
(3,967 Views)
Hi craige,
It looks like the document you linked only has information about a green and red LED, indicating successful or unsuccessful connection to the DataSocket server. The DataSocket server, which is on the same computer as your application, may be not running or may be denying connection.
Do you see a red LED, or just gray and green? If you hold your mouse over the LED, what is the message that comes up? How are you starting the DataSocket server?
Stephen S.
Applications Engineering
(3,942 Views)
Oops. You're correct. THIS documentation describes the gray led briefly.
http://zone.ni.com/reference/en-XX/help/lv/71/lvhelp/Subscribing_to_Front_Panel/
I occationally see red and most of the time the leds are green. On very rare occations the LEDs are gray in which case I don't know what to do. Green and red make sense. (usually red occurs when I shutdown datasocket server manually) To start the server I have a shortcut to datasocket placed in my windows startup folder.
Still havn't found the cause of this.
Craig
(3,910 Views)
On mouse over the LED tip strip reads "Connecting: Parsing URL". Situation sounds similar to these thread.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=152975
http://forums.ni.com/ni/board/message?board.id=230&thread.id=3554
I opened an application support number with the NI application engineers and I'm still waiting on my client to give me information regarding their suggestions regarding the windows firewall at this time.
(3,890 Views)
Hi craige,
Are you using the diagnostic tool? What OS are you running on?
What is the service request number that you opened with the applications engineer? It would be helpful to be able to find who you are working with so we can more effectively work on this issue.
Stephen S.
(3,881 Views)
