Datasocket fills memory
I´ve done an automatic setup vi to create a couple of user defined DS-Items
in LabView 6.0i (Windows2000) with a FOR-LOOP.
If possible please give some answers to the following topics:
1. The Program seems to work fine, but there are some problems over a use of
several hours. DS fills all the memory of the Computer till the system
hangs.
2. Using the the default DS Write functions in al loop the connection will
be erased after creating the next Item.
3. Is it possible to create a DS Configuration File with Labview? Could you
send me the file format for a DS Configuration File?
Thanks for your help
A.Franz
Message 1 of 1
(2,752 Views)
