Datasocket reference check
   How do you check if the data socket connection is valid or not ?
--trupti
(3,496 Views)
You can monitor the error cluster coming out of your Datasocket fuctions (open, close, read, write) to see if an error gets thrown or if there is a timeout due to no valid connection with the Datasocket Server.  You can build this error-handling into your code so that it can be specific to your application.  Once you have opened a connection, you can simply perform a Datasocket write or read and if it works without error, you know the connection is valid.
(3,480 Views)
You can also close and open the server if necessary by using the VIs in the Datasocket LLB found in vi.lib.
___________________
Try to take over the world!
(3,474 Views)
Hello All,
I believe that the easiest way to do this is with the "Not A Number/Path/Refnum?" VI?  I believe that this checks the validity of the datasocket connection.
hope it helps!
Travis M
LabVIEW R&D
(3,462 Views)
