Datasocket state
Hi all.. I have a system that write a data on remote datasocket ( Datasocket server on 2003 Server) and a client application that read data from datasocket server. The client application run on 2003 server machineand work perfectly.... in qualche caso ho la necessità di sapere se l'applicazione scrive realmente i dati, perchè può seccedere che c'è qualche problema di rete...sometimes I need to know if the application actually writes data, because it may happen that there is some network problem ... In this case I want to send an sms
tank you for your help
(2,789 Views)
Hello Loopin3,
Thank you for writing your problem on the NI Forum.
According to your description, i assume that your main problem is regarding to how to implement LabVIEW code so it could send text messages through SMS Gateway.
In this way LabVIEW can indirectly send text messages to a cellular phone with the SMTP E-Mail VI’s along with any SMS gateway service. If you want to investigate moreover the features of this procedure, you can start from the document linked below:
Can LabVIEW Send Text Messages to a Cell Phone?
Let me know if you need additional informations or effort.
Kind regards.
Matteo
(2,770 Views)
