Datasocket write error when launching an application
I have invested a lot of time in an applications that uses a number(>100) datasocket connections to exchange data between an application and plug in modules(called vis). I have two errors relating to the datasocket server for this application: 1.) When the server is started for the 1st time by calling the datasocket server control vi inside my code, I run a write function inside a loop for 10 iterations at 10ms intervals. No matter how I modify the number of iterations and frequency, the write function occasionally errors on first start up., and 2.) When I run the application using the Labview runtime engine(version 6.0.3) I see the same problem in addition to datasocket reads and writes not updating correctly. They do
not error but they do not exchange the correct data like they do when the full version of labview is installed on the machine.
Has anyone seen these problems before? Your help will be greatly appreciated.
Thank You,
Mike W
Message 1 of 1
(2,678 Views)
