Datatranslation link
Hi.  I am trying to write a LabVIEW program to interface with Datatranslation DT-LV Link's EMG equipment (www.datx.com).  It will need to acquire analog signals from 3 separate channels, graph and display them in real time, and save the raw data.  It will also have a digital out that controls an air valve, making it open and close at certain user-adjustable timings.  Would anyone have examples that can help me out?  Thanks.
Message Edited by RobinC on 10-12-2005 04:44 PM
(2,937 Views)
Hello Robin,
Data Translation created the DT-LV Link to communicate with their hardware from LabVIEW. With those drivers, you should get VIs and example programs that you can use to perform data acquisition from your board. In most cases, there are simple AI, AO or DIO VIs that you can call. If you don't have any examples, you can contact Data Translation's support site.
Jack J.
Applications Engineering
(2,918 Views)
