Date format in Microsoft Data Access
In the Data Access table one of the columns is a date format column. In some records I do not want enter date into date format cell. If I am not entering data into the date format cell, then when I am reading the cell content I get 30.12.1899--00:00:00 date.
What I have to insert into date format cell so that no date will be received during the cell reading?
(3,171 Views)
I am not going to be able to give you a complete answer but I may be able to get yous started.
I beleive you are seeing the Access zero date because the field is null.
In the SQL query you should include "ignore null" or something similar. I am not an SQL guru so that is as far as I can go.
Ben
(3,171 Views)
You may want to look into the database configuration to see if it is possible to save the date as a string that would allow you to set a "no-date" tag.
There is also the option to move to a string field and save the data manually. Also allowing you to define your own special tags for date.
I hope this helps.
Juan Carlos
N.I.
(3,171 Views)
