Date from a waveform is reset to dec 31, 1903 when inserted into a DB
When inserting data from a waveform into a database with the database toolset, my date is periodically - and seemingly randomly - reset to Dec. 31, 1903. What causes this?
(2,841 Views)
Dec 31, 1903 is LabVIEW's zero time (in GMT).
You will have to provide a little more details for us to help much beyond that.
Are you sure it happening in the database and not somewhere else?
Can you create a demo program that gets rid of everything except the DB activities and still has the problem?
Are you checking the error cluster when doing the DB updates to ensure they are being applied correctly?
Ben
(2,841 Views)
