Datron VXI DMM driver
I have a Datron VXI 1362 DMM that I need to be able to communicate with. I downloaded the driver for it but I am unable to run the vi/s because I have a missing file that the VXI send message and receive message vis use. I noticed that there is a driver for a Datron VXI 1362s DMM available. Would this driver be compatible to use with the 1362 DMM?
(3,047 Views)
It is possible that you need to install the legacy VXI libraries if you are running LabVIEW 6.0. I believe the driver works fine in LabVIEW 6.1 and later.
(3,047 Views)
