Dattalogger using API
Hi, I am trying to create a data logger using API from a smart device.
However I am facing issue with writing the data to the file. After the 1st loop, the reference value of the file becomes zero, and the data is not getting logged in the file. This is the first step of the project. I then want to load this file on myRIO and able to log data in myRIO
Message 1 of 8
(1,798 Views)
Hi mars,
This could happen when there is an error occuring inside the loop/case.
Does an error occur?
Did you know you can simplify your VI by using FormatIntoString with all its possibilities?
Like this:
Do you know you can show the "digital display" for your charts? (No need for separate indicators!)
Do you know you can change the formatting of digital/numeric indicators to also show an unit (like "W")? (No need for conversion to string!)
You know the myRIO will handle the file in its internal "hard drive"?
Do you know the myRIO doesn't have an UI and so it cannot use the FileDialog ExpressVI?
Message 2 of 8
(1,781 Views)
I did not know the myRIO doesn't have an UI. So, then what should I use instead of the FileDialog ExpressVI ? could you please guide me ?
Message 3 of 8
(1,760 Views)
Hi mars,
Do you see any monitor connector (like DP, HDMI, DVI) on your myRIO?
You need to define the filename programmatically, without user interaction…
I repeat: you know the myRIO only uses its "internal drive" and has no access to the storage of your host computer? (This is one of the main problems when unexperienced people use NI-RT targets…)
Message 4 of 8
(1,747 Views)
Thanks, I simplified the output with your suggettion..
I checked with the Probing tool , There is a error inside the loop.
error code : ERR(-375004). Is the shift register getting reset to zero because of this error ?
Message 5 of 8
(1,720 Views)
Hi mars,
You can easily test this with some more probes!
Now you should implement some error handling to handle that "too many requests" error! (Or even prevent it by don't requesting data so often!?)
Message 6 of 8
(1,705 Views)
I am trying to debug the code. However, just wanted to clear one doubt. We are about 25 students working on this same API from college lab. Is it possible that since everyone is trying to access this API, this issue is being created ?
Message 7 of 8
(1,686 Views)
Hi mars,
There are 20+ clients trying to access the same service.
The error message is about "service overload".
This might be pure coincidence - or cause & reaction…
Message 8 of 8
(1,682 Views)
