Deactivation of buttons
I want to add a deactivation of buttons function into my VI.
For example, when I first run the programme, I just want my 'Check' button to be functionable.
The other 4 buttons to be deactivated, only until 'Check' button is pressed.
Can this be done ?
Your help will be much appreciated.
(2,719 Views)
Use property nodes. You want the Disabled property.  You can set the controls to be Enabled, Disabled, or Diasbled and Grayed Out.  Generally Disabled (and not grayed out) is not recommended because it is confusing to users.
Lynn
(2,718 Views)
So, how is the other buttons 'enabled' after I clicked on 'Check' ?
(2,715 Views)
Accepted by topic author ThePotatoMan
Write to the same property node the Enabled value.
Lynn
(2,708 Views)
