Dead pixels finding with NI Vision
Hi to all,
I am new using the NI Vision Assistant environment and I am not very sure how much it is possible to do with it.
I am trying to do a search for dead pixels on a LCD from a picture taken of the same with NI Vision Assistant but I had found some similar posts in the NI Community that suggest to do this with LabView instead so I ask the following:
This is because NI Vision Assistant is not that powerful to perform such operation or because it is easier to do it with Labview?
I also take the opportunity to ask you if this is possible to do with LabWindows CVI?
Thanks in advance,
Best Regards,
Ramiro Javier Rossi,
Testing Engineer at Mirgor Argentina.
Message 1 of 1
(1,343 Views)
