Dear S7200 PLC controlled by LabVIEW 7.1
Helo,
I have a S7200 PLC CPU224 with Industrial Ethernet Module CP 243-1. I'd like to use this harware connect by Ethernet port pc, and Labview will be the controller for this plc.
How Can I connect and what is the interface between Labview / S7? We have the Simatic PC-Access CD, but I don't know if is necessary another thing.
Is someone available to help, please?
Thanks all!
(3,282 Views)
LabVIEW is an OPC client and can communicates with any PLC that has an OPC server.
I'm sending to you a link explaining how to communicates LabVIEW with any PLC that has an OPC server.
http://zone.ni.com/devzone/cda/tut/p/id/7450
Regards
Luciano Borges
National Instruments Brazil
Luciano Borges
Test Development Engineer
(3,247 Views)
