03-14-2013 05:21 AM
Hello Christ0phe,
I have double-checked the history of my actions and apparently the internal escalation went wrong.
I have reinitiated the communication about this.
My apologies for the inconveniences.
03-14-2013 05:48 AM
Hello
If at least you or someone else could first confirm that he/she experiences the same issue as me using the Vis that I have attached in my previous post it will be a good first step.
Then I will wait to get a patch.
Christophe
03-14-2013 06:21 AM - edited 03-14-2013 06:21 AM
Hello Christ0phe,
Thank you for uploading the files.
Can you share the 2012 version again because the zip gives an error?
03-14-2013 06:33 AM
So basically there are 2 main issues:
1) The fact that the code doesn't open at the PC(under debugging), but does at the pc (that is debugging) when you're using an executable.
2) About opening the globals
Is this only visible in the executables?
03-15-2013 05:30 AM
Hello Christ0phe,
Here's a quick update about issue 1.
Communication has been restarted and I'm currently waiting on a conclusive answer from one of my colleagues.
I'll keep you updated.
Please also reshare the zip that didn't work. Then I can do those tests.
Probably something went wrong with the upload.
03-15-2013 06:31 AM
Hello again,
The zip files open just fine on my PC but here it goes once more. I also send you the 2 attachments to your N.I. email address.
I would like also to say that the problem with the globals not being refreshed is only in the .exe, not in the Labview 2012 full development system.
Christophe
03-15-2013 11:33 AM
Hello Christ0phe,
I didn't see anything coming in on my NI mail address.
I'll check the code maybe this weekend (if I find the time).
Otherwise i'll check it on monday.
I'll also keep you updated about the escalation.
03-20-2013 08:34 AM - edited 03-20-2013 08:34 AM
Hello Christ0phe,
On Sunday I tried to download it from home but the 2012 version was still corrupted.
Yesterday and monday I was working for our local SSP day.
Today I tried again on several pc's and the 2012 version is still corrupted.
In attachment you can find the screenshot:
Can you try to upload it in another format? (rar?)
03-20-2013 08:45 AM - last edited on 03-20-2013 11:06 AM by JordanG
Once again, attachment here and a copy once again sent to your personnal mailbox and also to Julien Roland. I hope this is enough ! Attachment readable here from another PC than the one on which the code was originally programmed.
03-20-2013 09:56 AM
Now I did receive the e-mail.
Please remove the posted support e-mail address from your post.
I will ask our webteam to remove your last post, because of the posting of that e-mail address.
