Debug problem with native VI
Hi
I have problem with native VI used to initialize the instruments: Fgen, Scope, DMM, DCPower sypply with options.
As it is attached, the program goes into a loop in this functions and I only can abort it resetting LabVIEW.
I am using LabVIEW 2015 and the instruments are included in a PXI chassis.
How can I debug the error to know where is the problem?
Thanks!
Message 1 of 11
(6,456 Views)
@uhernand wrote:
Hi
Thanks!
No, as it is attached it opens in my image viewing application
Message 2 of 11
(6,434 Views)
You also have too many local variables, too many sequence structures, and zero error handling.
Start with something simpler. Do a single initialization. If one works, add another sequentially (without the sequence structure, course).
Message 3 of 11
(6,423 Views)
Why I don't understant is why it was working perfectly with this amount of local variables and sequences in LabVIEW 2009 and 2010 and not in LB 2015.
How can I know where is the problem?
Message 4 of 11
(6,394 Views)
Any time you make a change, the program is recompiled. Every time it's recompiled, you have the possibility of exposing the bad behavior of local variables. A bad design originally that luckily works, did not mean the bad design will always work.
Message 5 of 11
(6,373 Views)
I am sorry, but this design was been working properly for years (yes, for years) in LV 2009.
Leaving this issues apart, How can I debug my problem?
Message 6 of 11
(6,333 Views)
So you want to fix the problem without addressing the problem..... ? Smiley Frustrated
Message 7 of 11
(6,328 Views)
Have you tried to open the VI's to look where they are stuck?
Have you tried to disable temporary some of the VI's, just to focus on one of them?
What data is comming into the VI's, are they getting valid data all of them?
Message 8 of 11
(6,315 Views)
Is the code running on the same machine as the LV 2009 version?
Does the LV 2009 code work on the same machine?
Message 9 of 11
(6,312 Views)
Since you have not included any error handling to catch problems, your debug is going to be much more difficult. You haven't attached any code so that someone can review it.
Message 10 of 11
(6,296 Views)
