Decimate all the column of an 2D array
I have a 2D array, and i want decimate all the column of this array into a 1D array
Message 1 of 22
(4,578 Views)
hello,
yes you can use the redim function in array palette,
see pict attached
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 2 of 22
(4,573 Views)
I thinks there is understanding,
What i want isn't one 1d Array, it's 1d  Array for each column
Message 3 of 22
(4,566 Views)
ok,
so use  X index function also in array palette,
an cable numeric on columne entry ,0 to first 1 to second ...
Regards
Tinnitus
Message 4 of 22
(4,560 Views)
Sorry i dont understand.
Just to be sure
I don'know the number of column i have. So i would like to know if there is somethings link unbundle for cluster.
Message 5 of 22
(4,558 Views)
what do you want to do ?
what is the aim of this code ?
Message 6 of 22
(4,550 Views)
oki i will try to be clear,
You would like to separate X column of a 2d array in X 1d array
So per example:
2 3 4 5 6 7             2  I   3   I  4
8 8 8 8 8 8    >>>> 8  I   8   I  8 , etc....
9 9 9 9 9 9             9  I   9   I  9
The idea i get was to use a kind of unbudle cluster but is not working as the vi show you.
For that i asking to the forum if someone have an idea
Thanks for your patience
Ben
Message 7 of 22
(4,542 Views)
sorry that was not my question
what the real aim , to do what ?  display , file recording
what the problem with index function ?
Tinnitus
Message 8 of 22
(4,537 Views)
 The problem is when i use Index Array is not working. Index array didnot allow me to use the column as i wish.
The aim is to get acces at one column without any manipulation.
I want to be able to separate X column of 2D array in X 1D array
I don't know the number of column iwill have to treat.
So the purpose of the question is to separate X column of 2D array in X 1D array.
Ben
Message 9 of 22
(4,532 Views)
Or more than one,
Make the sort i want beetween the column
When you create an array you concatenate value or array, i want to do the opposite.
Ben
Message 10 of 22
(4,529 Views)
