Deciphering the write_dig_line.vi
I am trying to decipher the write_dig_line.vi.
First, there is a menu control for all the physical channels. How did this get into the vi? I don't see it anywhere in the functions palette. How did it get populated?
Second, this menu control for all the physical channels lets me specify the device, port and line. But in the default configuration, "one channel for all lines", the one-D array of booleans seems to apply to the each of the lines of the chosen port regardless of which line is chosen in the menu control. In this case, shouldn't it just be listing the ports only? I can switch among the lines in the menu control and the outcome is not affected.
Third, when the task is cleared, it has no effect on the digital lines. They remain where they were set last. Shouldn't their voltages revert to where they had been before the task was started?
(3,711 Views)
Accepted by topic author mauricev
The control is a DAQmx physical channel that can be found in the IO>DAQmx Name Controls palette.
Physical channels can be a single channel or a list of channels. Search the help for physical channel syntax.
Clearing a task is just saying that you are freeing the resource up, not actually writing any new data to the device.
(3,681 Views)
Thanks for pointing out where the physical channel control is. I have since learned that right-clicking and choosing I/O Name Filtering, one can set which channels appear. I have also learned that this vi uses typed syntax to specify a port as Dev1/port0/line0:7. The 0:7 specifies all the lines of the port.
(3,607 Views)
