Decoding NIST WWVB signals with LabVIEW
Hi All,
I was wondering if anyone had code for decoding the NIST WWVB signal from CO.  Wikipedia: http://en.wikipedia.org/wiki/WWVB
Sometimes this is incorrectly referred to as the atomic clock.
Since this is fairly old I figured there would be something on the forums but to my surprise nothing I could find.
This is for a specific application where I need a very low cost timing signal outside.  I have a receiver outputting the signal shown in the Wikipedia link above and access to LabVIEW I/O input DAQ, CRIO, sbRIO etc.
-SS
(3,480 Views)
Hi Simon,
I've been doing some digging, and was fairly surprised when I also came up empty-handed.  That being said, I think the simplest way to implement this would be to call a DLL using the call library function node.  If you do end up building this in LabVIEW, I'm sure that it would be well received on the developer community.
Tom L.
(3,455 Views)
Interesting project!
I looks like a few people have tackled decoding the data (both WWV and WWVB) using reciever modules that create a digital signal stream and Arduinos to decode the data.
How about GPS based time? Here is reciever/decoder module that provides a decoded serial data stream:
http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/GPSManualV1.1.pdf
-AK2DM
(3,445 Views)
