Decoding bit values, (e.g. bit# 7 (MSB, 0=LSB) in 0xFF = 1)
I needed to "decode" or read out the bit-status of any specified bit in any given number (from U8 to U32), and as such I made a "tiny" VI to give that functionality.
Since I'm rahter fresh to this whole game, I would like to get some feedback on the code.
The VI will be used as a sub-vi in a larger project, to decode status bytes which I can then use to control indicators for various processes.
I've inlcuded just a little bit of documentation, but I have not yet made an icon as my preffered icon editor is on a different computer.
I suspect I'm not as efficient in this vi as I could have been, but I'd like some feedback whether or not I have made any big boo-boo's, say on a scale from 1 to 10 with 10 beeing perfect. 🙂
One comment I can give myself is that the U8 for bit-position is converted when passed to the for-loop... but on the other hand, it feels "wrong" to use the default data-type here, since the maximum value that makes sense to pass to the vi is 31 (for an U32 data-type).
Project Engineer
LabVIEW 2009
Run LabVIEW on WinXP and Vista system.
Used LabVIEW since May 2005
Certifications: CLD and CPI certified
Currently employed.
(5,109 Views)
I usually transform the data to a bit array.
(5,104 Views)
Absolutely sweet!
Sometimes the biggest challenge with LabVIEW is to find all those pre-made functions! -I find myself "re-inventing the wheel" on several occasions, just because I did not realise that LabVIEW already had the code tucked away on some panel!
Thanks!
Project Engineer
LabVIEW 2009
Currently employed.
(5,101 Views)
If you don't want to go through the expense of allocating a 32 byte boolean array, you can just use a plain masking operation. Remember that the logical operations perform bitwise on integers. (scale by power of two is very cheap for integers, because it uses a simple bit shift, same as in example 2).
Message Edited by altenbach on 12-04-2005 04:03 PM
(5,083 Views)
okay.. this reply is very late I guess, but better late than never!
I just wanted to thank you, Altenbach, for your contribution, I will use this technique in my current VI.
Thanks!
Project Engineer
LabVIEW 2009
Currently employed.
(4,985 Views)
Tight.
I can use this as well.
Thanks.
(4,817 Views)
