Default Control Style
I assume this should be an easy task but I haven't stumbled on a solution yet.
I used an example vi to create something new and the default style in the sample vi was set to classic. Did a save-as to create a new one and every control and indicator I create from the block diagram is in the classic style. Is there a way to change it so new ones are created in a different style? So far the only way I've found is to copy and paste into a new vi.
The default has already been set to modern (my fav) as per this guide: http://digital.ni.com/public.nsf/allkb/9B3AF1A89123340A86257A09004C9DBF. That only has an effect on new vis though.
Is there a way to change the default control style of an existing vi?
(5,840 Views)
Accepted by topic author B_Strange
VI Properties->Editor Options
There is a radio button for the default style on the VI.
(5,835 Views)
Thanks. I hoped it was hiding somewhere.
(5,830 Views)
